1 - 19 of 19 Posts
The folks I bought my Jeep from put new bulbs in front and rear. It worked but blinked really slooooowww. Now it stays solid so I have to work it manually on off on off. Turn the hazards on and works as it should. Turn the hazards off turn the blinker on and it stays solid. The rear tail light housing is broken and there was moisture in it and I have a replacement on the way. Anyone heard of this or have suggestions?
Possibly the turn signal flasher. You should have two. One for your hazards and one for your turn signals. Try switching them to see if that fixes your signal problem. They should both be the same so you could leave it in until you can get a replacement for your hazards.
Simple fix and you can buy some time to get to the store by swapping them and maybe they will both start working since the hazards work differently then the turns do. If that doesn't fix it which it should we can then go from there.
Didn't get to work on signals today. Changed crank case and tranny oil then ran out of daylight. Will be on list to do this weekend. Thanks for the help.
Discussion Starter · #10 ·
Well that fixed turn signals but I have other electrical gremlins. When I have the headlights on and turn the turn signals on I lose all my lights on the back. The driver side rear tail light housing is cracked. I have another one ordered that should be here next week and I will start on that issue then. Thanks all.
Discussion Starter · #13 ·
My new light came in and I installed today. Everything worked great. Swapped the flasher back around to the way it was and everything works as it should. Thanks to everyone for the help.
The flasher is a round thing that plugs into the fuse panel. There should be two of them plugged in there. One for your hazard light and one for your turn signals.
They look like this.
One to give you perspective on size.
1 - 19 of 19 Posts
