If you haven't exposed the engine to water, the most likely culprit is head gasket. Is your radiator low? Is the antifreeze the proper color? Is there foam in the radiator? As Rik stated, the more information you can give, the better we can help to diagnose the problem. As far as treatment, there is no treatment that I have heard of that can help. You must find the root of the problem and fix it.
