This fall, you have an opportunity to save 20% on aFe Scorpion Grills at CARiD. The offer ends on November 30, 2020. Prices are already reduced.
This grille will turn heads with its rugged, off-road style and provide your front-end with high-output illumination. Every aFe Scorpion Grille is specifically-created for your Jeep Wrangler. It's designed as a direct replacement for quick and easy installation. It features steel construction with a two-stage black powder coat finish that provides rust- and corrosion resistance.
aFe® - Scorpion Series Tread Design LED Grille
  • One-Piece Laser-Cut Design
  • Two-Stage Powder-Coated Finish
  • Built-In LED Lighting
  • Stainless-steel hardware is included to provide the best corrosion resistance possible for each application
Includes:
  • 1-Pc main grille
  • Military-grade wiring harness
  • Stainless steel installation hardware
With aFe Scorpion Series LED Grille on your Jeep Wrangler is going to stand out!
