Ok so my rig has about 4 inches total lift maybe a little less. It has a drop pitman arm yet for some reason the drag link is at such an angle that it causes the tie rod to rotate creating about 4 to 5 inches of slop in my steering wheel. its a pain to drive on the highway and im ready to do something about it.
Im just not sure if i have enough lift to do a high steer kit or not, and i figure its not lifted enough to require the use of one. does anyone know the maximum amount of lift you can put on a yj and still run the stock steering setup?
Thanks!
Its steered a bit to the right in this pic and you can see the tie rod is rotated down.
Thanks!
