Step 1:
Sentence structure!! It's very helpful to get your message across as clear and concisely as possible so we can understand what you're on about.
Step 2:
Remove your track bars. They create unnecessary stiffness in the suspension quality and do not allow the springs to flex, not hardly at all. They are not required for leaf springs, and were only put in place to, essentially shut the hippies up.
Step 3:
Run your tires at the proper tire pressure. 31" tires like to run around 32-35psi on the roads.
Step 4:
Double check the shackle bolt torque, and yes greasing them is required (if you want everything to rotate smoothly).
