I had the same problem with it happening in first gear, on acceleration, It was the transmission boot, under the stick shift boot. Carefully pry your stick shift ring up, slide both boots all the way up. Before you snap your beezle ring back down, drive around for a while and see if it happens again.. Good luck.
