1 - 5 of 5 Posts
hey all,,,,,,,, having panhard problems......as in keeps working loose ..:(
heres the set up........
and thats the nut that works loose...........not over time , but about every 2nd run i gotta swing on it......
so i want to change the set up...
what are you guys who have modified yours running......
now jeeps a 97 RHD on about 4 inches of lift running 33s.....
thanks
wayne
Run a heim that has a horizontal cross bolt. That nut coming loose is a common malady.
Make a bracket that attaches to it and the frame and you are good. RE and Rock Krawler make a bracket for LH side drive Jeep that will give you an idea as to what to built
Full traction makes a good one, I use it and have never had any problems since input it on. They make 2 and i run the one that crosses over and also attaches to the frame
1 - 5 of 5 Posts
