1 - 3 of 3 Posts
I will try to make this short and sweet in order to make this easier. I have a 14 JK Sport and I am currently in possession of 325/70/17 Tires and Rims. I am looking to know what my beginner options are for light off roading and mostly a daily driver.
I was looking at a 2.5 in TF lift kit BB and a 1.25 Rough Country Body Lift.
Do I need axle sleeves with this set up? Is there a better choice in what I should do? (Roughly 1200 Budget)
Thanks for the help in advance!
Newbie build question
If I'm correct the 325-70-17 comes out as a 35 inch tire. Do a 4 inch lift only. That will clear those tires no problem, Everyone I know that has done a body lift on there JK hated them as it made their Jeeps unstable or rather rocky in the ride. With your budget you can get a good lift kit for that or less. if you are going to use your stock rims then get 1.5 inch wheel spacers or invest in some new rims with better back spacing maybe 3.5 inch. talk to others in your area that own Jeeps for their advice as well.
1 - 3 of 3 Posts
