Today, we’re here with the all-new custom-fit combo of 3" Cube 4D Optic LED Pod Lights & A-Pillar Dual Light Mounting Brackets engineered by Lumen to make your off-road experience even more safe and enjoyable. Explore the hidden trails with our set of 4 auxiliary lights and A-Pillar mounting brackets to match.
Lumen - A-Pillar Dual Light Mounting Brackets For Four Pod Lights
Includes:
Two brackets
Stainless steel mounting hardware
  • Custom designed for your make, model, year to ensure easy installation and perfect light fitment
  • Provides reliable light stability under all driving conditions
  • Eliminates the need for complicated, time-consuming and costly fabrication
  • Sturdy solid steel construction
  • Stylish black wrinkle finish
  • Stainless steel mounting hardware
  • Warranty: 5 years
Lumen - 3" Cube 4D Optic 20W Spot Beam LED Pod Lights
Includes:
Two lights
Universal stainless steel brackets and mounting hardware
Complete dual wiring harness
Illuminated toggle switch
  • Spot beams provide concentrated light to penetrate the darkness and illuminate points far in the distance
  • Powerful Phillips ZES LED chips deliver brilliant light with less energy consumption and longer bulb life, as much as 50,000 hours or more
  • 4D convex lenses project light further than ordinary auxiliary lights
  • 5W LEDs
  • Sturdy die-cast aluminum housing
  • Corrosion resistant finish
  • Waterproof
  • Shock and vibration resistant
  • IP67 ingress protection rating
  • Warranty: 5 years
Learn more about the latest Lumen Release in this write-up.​
