If you’re looking to upgrade the tail lights on your JL Wrangler, look no further. Introducing Sequential LED Tail Lights from Form Lighting. Not only will you stand out on the road with a more modern appearance, but you’ll add dual reverse lights, a sequential turn signal, and a unique startup sequence.
Modern Appearance. Unlike many other aftermarket options on the market, these tail lights were designed with factory-style optics, to diffuse the light in a smooth, even appearance. The outer perimeter of the lamps illuminates in a solid bar for running and brake/turn lights. On the interior of the lamp, you’ll find a unique “infinity mirror” design, for a truly distinct and premium look.
Smoked, Not Sprayed. Nightshade? No thanks. These tail lights are available in two lens colors, red and smoked. The smoked option is designed with tinted optical components, which provides a factory-quality smoked appearance - not a cheap painted look like others on the market. The red option maintains the same quality, and keeps that OEM appearance, while still being a great upgrade.
Startup Sequence. These tail lights are packed with modern features, including a unique startup animation. Anytime the running light turns on, they will illuminate in a chasing sequence that is sure to turn heads.
Sequential Turn Signal. The startup sequence won’t be the only thing turning heads. These tail lights also feature a sequential LED turn signal. Every time the turn signal is activated, amber LEDs sequence across the top of the lamp. To enable this feature, a simple wiring harness is included that will be run up to the front turn signals, and connected with a wire tap.
Dual Reverse Lights. The stock tail lights come with a single reverse light in each lamp, and leave a lot to be desired. With dual LED reverse lights, the Form Lighting tails provide much more light when backing up at night.
OEM-Grade Construction. Form Lighting tail lights are built with quality in mind and constructed using OEM-grade materials, including a UV-coated polycarbonate lens, automotive-grade LEDs and optics, and direct-fit connectors. While they may not be the cheapest option on the market, the fit and finish of our lamps is superior to other aftermarket units.
Road Legal. Both lens color options illuminate with red LEDs, and feature an integrated retroflector sidemarker and running light, just like the factory lamp. These lamps are SAE and DOT-compliant for on-road use.
Plug-and-Play. Our tail lights for the Wrangler are plug-and-play for the main functions, along with a single wire tap if you’d like to enable the sequential turn signal feature. They will fit perfectly, without any body gaps. Installation is a breeze and can be done in minutes. Unlike other options on the market, these tail lights are also fully compatible with the Wrangler’s blind spot detection system, if you have it. There are no blind spot system errors, flickering, or hyperflashing!
Click the video below to see HOW to install our 2018-2023 Jeep JL Wrangler Sequential LED Tail Lights!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. In the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Jordan M.
Form Lighting
