1 - 8 of 8 Posts
do you have to change dist or any computor wires (is that the nutter bypass) i hear everyone talking about, also the vac advance from the dist is it removed? thanks
The vac advance is still used. The '87 I converted had no actual 'computer,' it has the distributor with magnetic 'points' -- I didn't touch that stuff. You can see the vac advance line in this photo [http://saragossa.net/i/uploaded_imgs/weber34dgec_installed.jpg] connected to the driver-side port of the adapter manifold under the carb. It snakes way around the front and back, then up over the valve cover and down to the distributor diaphragm.
Links not working.
1 - 8 of 8 Posts
