1 - 9 of 9 Posts
Have a 97 wrangler with 4.0 in it. (before you jump and say the 97's and early 98's have a bad batch of valve springs... The motor is out of a 94)I have the code 43 misfire on cyl. 2,3,4,5 and 6. Somthing about primary Coil circut A and multipul missfires. Ive replaced cap, rotor, wires, plugs and ive tried 3 coils. The problem has gone away then comes back shortly after. Im leaning towards a pcm but wasen sure if anyones had this issue before
Misfire
I had 2001 tj with 4.0 that would code misfire and after replacing everything except ECM still didn't fix it. After research it was the valve springs. I know how it sounds but that was it after replacement no codes after 10k miles. There was an article in J&P about it in the tech section. Hope it helps.
Misfire
I want too make this as clear as I can so there is no misunderstanding, ok here we go. First off there is no bad batch of valve springs. I also had over 100k miles on the Jeep. I had a misfire code set at an idle as well as one being set at 75mph. Never once felt a miss? Replace plugs, coil pack, crank sensor, flush injectors and never could figure it out. In J&P magazine there was a Jeep Tech with the same problem on a 4.0 Cherokee. He replaced the spring on the cyl that coded and it fixed it. In turn I replaced all my valve springs and it fix mine. If it had not been for the Jeep Tech and a open mind I never would have fix it. As for your Jeep, I hope you fix it, I thought it I might be worth telling you if you get up against the wall and can't figure it out, think outside the box, it help me all though I couldn't wrap my head around it at first.
Ok thank you, your right i should look outside the box on this one. However just as an fyi service bulletin number 18-22-98 is the bulliten for problem with the valve springs witch was released in december of 97. The bulletin involves installing revised valve springs and decarbonizing the cumbustion chamber.
Service bulletin
Thanks for the info, I did not no that! I started with pulling the code, than I ran a compression test very first thing just to double ck. I was told that a weak valve spring could let the valve bounce just enough for the computer to detect a misfire. This went against my thinking but I guess it turned out to be the case for me.
Resident Grouch
I wonder if it was the springs or the carboned up combustion chambers. I'd try decarbonizing it first, then do the springs.
1 - 9 of 9 Posts
