Decided that I should upgrade my headlights on the Jeep. As we all know, the stock headlights aren't anything to brag about, and even some of the supposed "performance" sealed beam lights don't put out a lot. The main reason this is so is because of the wiring harness Chrysler decided to use for their lights- the wires are just a bit too small and a lot has to pass through some other components, which lowers the initial output voltage to the headlights, making them dim. You might lose up to 400 lumens (or more if your wiring is at the end of its life), which is a LOT of light (keep in mind our sealed headlights can only put out about 950 lumens at full power).
This is a basic writeup on how to re-wire your headlights so that they can put out the MOST light possible. This can also work for wiring up some auxiliary lights, reverse lights, even sealed beam conversions.
First, we will start off with a basic list of components you will need:
-2x: 85, 86, 87 style 4 pin relays
-2x: 85, 86, 87 style 4 pin relay sockets
-2x: in line fuse holders
-12-14ga wire, about 10 feet of RED and 1-2 ft. of BLACK.
-Soldering iron, good quality rosin core solder, and some basic soldering skills
-Heat shrink tubing
-Heat gun
You can purchase everything from RadioShack if you want or you can get them from Amazon. Amazon is going to have cheaper components, both in price and quality. I bought my relays and inline fuse holders from RadioShack. Cost me almost $20, but they're high quality components.
Nice 12ga wire on them fuse holders.
TO BE CONTINUED
(I still need to pickup some wire and some relay sockets, and other misc. components, hang tight)
-Heat shrink tubing
-Heat gun
TO BE CONTINUED
