After many requests, we finally saw the light and would like to introduce you to the Metalcloak Oil Pan Skid for the Jeep 4.0L engine.
Compatible with most 4.0L Configurations including TJ/LJ/MJ/XJ/YJ/ZJ/WJ, there may be minor modifications needed depending on your exhaust set up.
A simple, yet effective design, the Oil Pan Skid is:
As always, your feedback is appreciated.
- Laser cut
- 7GA steel
- CNC formed
- Bolt on (no welding required)
- 3 times the strength of OE brackets
- Mounts to existing attachment points
- Clear Zinc for the best corrosion protection
