The most critical part of the job was skipped, ensuring the part of the crank where the bearings are is in good shape, they are called the Crank Journals. Then measuring it super carefully, and getting the exact right bearing shells. Then using plati- gauge strips of the right size(colour) for your job, put a piece on each bearing, install crank, and torque to specificatioons. Then undo it, and pull crank back out, and measure the now squished to wider Plasti-gauge stips, and see if the clearance is correct. Also noot much point in doing just mains, while its apart do the Rod bearings to. Hope its just that, not something worse. Been there on this very issue, just that it wasn't a Jeep. Mine should have been warranty, but it is a crooked car company, so my son fixed it, and I 'assisted' ( slowed him down and asked a bazillion questions) It was better after.
