97, Had it since Oct.
Floor is wet on the drivers side after a good storm, no obvious water tracks on the firewall that I can see.
I pulled the cowl off a couple of weeks ago, area directly under the cowl is clear and I can't see any debris in the drain...(I'm assuming the drain is the hole in the center, could the drain be plugged waaaay down in there?). All of the seals around the cowl look good.
If the Jeep is backed into the driveway,facing downhill during rain, there is a half dollar size puddle caught in the treads of the mat directly beneath the steering column.
If it's facing uphill, the mat is dry, but the floor under the mat is soaked and much wetter than if facing down hill.
Windshield seal is good, no obvious leaks in the top and no water trails anywhere that I can find. It has GOT to be coming in along the firewall somewhere because NOTHING ELSE is wet except the floor
Any ideas?
Any ideas?
