1 - 16 of 16 Posts
Automotive Lighting Experts
Jeep Wrangler LED Turn Signals
Click to order or for more information:
Front Turn Signal LEDs for 1997-2006 Jeep Wrangler
Front Turn Signal LEDs for 2007-2017 Jeep Wrangler
Bulb Design:
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
HP24 Switchback:
The HP24 bulbs use 16 amber, and 8 white LEDs. They are very high-power chips. More importantly, the amber is a custom-made LED chip. Instead of a standard amber, which emits a low-energy amber light, the amber LEDs on this bulb are downconverted from blue, just like a standard white LED. It is extremely bright amber. Equipped with full aluminum body for durability and advanced digital latching circuit for color control. 6000k, Cool White to match your HIDs or other LED applications.
Included in your order is TWO BULBS.
Hyperblink Fix: The turn signals on most vehicles will begin to blink fast (hyperblink) when LED bulbs are installed. This is because LEDs use less power than the original bulbs, so your vehicle thinks that the bulb is out. There are two ways to fix this:
Resistor Kit: This is a universal way to fix the issue, and will work for any vehicle. By adding a resistor to the bulb's circuit, you can mimic the power consumption of the original bulb, and return the vehicle to normal turn signal speed. The installation takes 10-15 minutes, and involves making two simple connections. Everything you need is included in the kit. If you have both front and rear LED turn signals, you usually only need one set of resistors, on the front or rear, to create enough resistance for the turn signal circuit.
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty. For more information, please view the FAQ guide.
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
(Single Color Amber Options)
Discussion Starter · #6 ·
Don't settle for generic LEDs! Diode Dynamics LED Turn Signal Bulbs are fully designed and tested in St. Louis using the best components available. Additionally, we back every LED upgrade we offer with a 3-year worry-free warranty!
Don't forget to shoot us a PM for free USPS shipping on ANY U.S order!
Jake H.
Discussion Starter · #9 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 12/2/2019, you can use coupon code "BLACKFRIDAY" at checkout for 20% off your entire order of lighting upgrades, including our NEW SS3 LED Pods!!! Don't wait, this sale ends TONIGHT!
Jake H.
Sale ends 11:59 p.m. CST on Monday 12/2/2019. Cannot be combined with other coupon codes.
Discussion Starter · #12 ·
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our Turn Signal LEDs, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
Sale excludes preorders.
Discussion Starter · #14 ·
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Turn Signal LEDs, with coupon code "LABOR" at checkout! Plus, get a free Diode flag tee when you spend $300! HURRY, this sale ends TONIGHT!
John C.
Discussion Starter · #15 ·
Now's the time to upgrade your ride! Our Black Friday Sale is going on NOW! Save 15% sitewide, including our Turn Signal LEDs, by entering coupon code "BF21" at checkout! And, all orders over $500 will receive a free Diode Dynamics long sleeve shirt! Sale ends Tuesday, 11/30/2021.
John C.
Sale ends 11:59 p.m. CST on Tuesday 11/30/2021.
Discussion Starter · #16 ·
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Turn Signal LEDs, with coupon code "BF21" at checkout! Plus, get a free Diode Stage Series long sleeve shirt when you spend $500! HURRY, this sale ends TONIGHT!
Click HERE to Shop!
John C.
Sale ends 11:59 p.m. CST | Tuesday, 11/30/2021.
Cannot be combined with other coupon codes.​
1 - 16 of 16 Posts
