Superlift is one of the most well-known names in the suspension industry today, offering the best and most suitable suspension solutions for your requirements. Today we are here to introduce its latest release for the 2020-2021 Jeep Gladiator - 4" Front and Rear Suspension Lift Kit.
Unlike other lift kits, it features all-new dual-rate coil springs that will provide excellent ride quality on-road while allowing more extension for off-road use. These new dual-rate coils will also provide an even stance and long-lasting durability. The kit also includes a front adjustable track bar, shock extension brackets or Fox Shocks, compression stop spacers, and extended sway bar links.
Superlift® - 4" Front and Rear Suspension Lift Kit
Specifications:
Includes:
If you want to drive through the rugged path with greater confidence, choose Superlift!
Specifications:
- With Front and Rear FOX 2.0 Series Shocks
- Install Time: 3-4 Hours
- Install Difficulty Level: 2 of 5
- Max Tire Size: 37"x12.5"
- Wheels and tires recommended parameters: Tire Size – 37"x12.5" R17, Wheel Size – 17"x9
- Tire Size – 37"x12.5" R20, Wheel Size – 20"x9
Includes:
- Dual Rate Front And Rear Coils
- Adjustable Front Track Bar
- Front And Rear Sway Bar Links
- Bump Stops
- Rear Upper Control Arms
- Brake Line Brackets
- Carrier Bearing Spacer
- Front and Rear FOX 2.0 Series Shocks
