This is exactly what I did! Worked like a charm. Takes a little working back and forth but be ready when they finally come off they can be a bit heavy. I also sprayed a bit of lubricant in each time they lifted a little.Hit the hinges with some PB Blaster. Let them sit for 30 minutes or so then swing them back and forth with upward pressure to see if that will loosen them up for ya.
