1 - 16 of 16 Posts
Automotive Lighting Experts
Jeep JL Wrangler Fog Light LED Bulbs
Diode Dynamics carries LED bulbs for replacement of your Jeep JL Wrangler's fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your JL Wrangler's fog lights a nice bright white that closely matches factory-equipped HID or LED lighting!
Just simple plug and play, replace the OEM halogen bulb and you are good to go!
Diode Dynamics offers the brightest, highest-quality bulbs on the market. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits your JL Wrangler's output needs best. These options are listed by the design and the lumen output of each bulb, compared to the factory halogen bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
SLF: 850 lumens. Street Legal Output. Much brighter than factory. These are bright! USA Made!
*SLF is available in 3000K Yellow / 5,700K Cool White color temperatures
Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Jeep JL Wrangler Sport Model).
Diode Dynamics' products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Diode Dynamics: Fog Light LEDs for 2018+ Jeep JL Wrangler
Click below for more info or to order:
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Think all LED fog lights are created equal? Think again! Check out this comparison of our SLF LED Fog Light Bulbs compared to a generic design commonly found on Amazon or eBay. As you can see, the generic option doesn't focus the light output, causing lots of glare and wasted light. By comparison, the SLF's advanced optical design matches the filament location of the original halogen bulb, providing the same clean, focused beam pattern as the stock bulb - only much brighter!
Ready to upgrade the fog lights on your ride? Click here to use our Vehicle Finder tool!
And don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Our Black Friday sale starts NOW! Today through Monday, 12/2/2019, save 20% on all LED upgrades including our SLF LED Fog Light Bulbs by entering coupon code "BLACKFRIDAY" at checkout!
Jake H.
Sale ends 11:59 p.m. CST on Monday 12/2/2019. Cannot be combined with other coupon codes.
Discussion Starter · #6 ·
SAVE 20% SITEWIDE! Use coupon code "BLACKFRIDAY" at checkout for 20% off all LED upgrades for your ride, like our Pro Series Demon Eyes! Hurry, this sale ends soon!
Jake H.
Discussion Starter · #7 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 12/2/2019, you can use coupon code "BLACKFRIDAY" at checkout for 20% off your entire order of lighting upgrades, including our SLF LED Fog Light Bulbs! Don't wait, this sale ends TONIGHT!
Jake H.
Our Memorial Day sale starts NOW! Today through Friday, 5/29/2020, save 20% on all LED upgrades, including our SLF LED Fog Light Bulbs by entering coupon code "USA20" at checkout!
Collin
Sale ends 11:59 p.m. CST on Friday, 5/29/2020. Cannot be combined with other coupon codes.
Discussion Starter · #9 ·
There's no better time to upgrade! Through Friday, 5/29/2020, get 20% off all our LED upgrades for your ride, including our Fog Light LED Bulbs with coupon code "USA20" at checkout!
Collin
Sale ends 11:59 p.m. CST on Friday, 5/29/2020. Cannot be combined with other coupon codes.​
Discussion Starter · #10 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 5/29/2020, you can use coupon code "USA20" at checkout for 20% off your entire order of lighting upgrades, including our SLF Fog Lights!!! Don't wait, this sale ends TONIGHT!
Collin
Discussion Starter · #11 ·
Our July 4th sale starts NOW! Today through Monday, 7/6/20, save 15% on all LED upgrades, including our SLF LED Fog Light Bulbs by entering coupon code "JULY4" at checkout!
Collin
Sale ends 11:59 p.m. CST on Monday, 7/6/20. Cannot be combined with other coupon codes.
Discussion Starter · #12 ·
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our plug-and-play LED Bulbs, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
Sale excludes preorders.
Discussion Starter · #14 ·
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our all Fog Light LEDs, with coupon code "LABOR" at checkout! Plus, get a free Diode flag tee when you spend $300! HURRY, this sale ends TONIGHT!
John C.
Discussion Starter · #15 ·
Now's the time to upgrade your ride! Our Black Friday Sale is going on NOW! Save 15% sitewide, including our plug-and-play LED Bulbs, by entering coupon code "BF21" at checkout! And, all orders over $500 will receive a free Diode Dynamics long sleeve shirt! Sale ends Tuesday, 11/30/2021.
John C.
Sale ends 11:59 p.m. CST on Tuesday 11/30/2021.
Discussion Starter · #16 ·
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our all Fog Light LEDs, with coupon code "BF21" at checkout! Plus, get a free Diode Stage Series long sleeve shirt when you spend $500! HURRY, this sale ends TONIGHT!
John C.
Sale ends 11:59 p.m. CST | Tuesday, 11/30/2021.
1 - 16 of 16 Posts
