Have your rotors turned and install new pads.Did the trick on my LJ.jeep98 said:It only happens when I put on the breaks.
:thumb: ill have to check that out when I get to a computer.DriveOffroad said:Our own Offroad Dave wrote a blog on Jeep death wobble and gives some areas to look and check. Many things you can do yourself and see if it will eliminate your death wobble.
http://www.driveoffroad.com/blog/2012/06/22/jeep-death-wobble/
Then you do not have death wobble, you have a warped rotor or drum. Get a good brake job, replace the rotors or drums don't turn them.It only happens when I put on the breaks.
I have had this problem with other vehicles. If you have disc brakes the rotors may be warped. If you have drum brakes, the drums could be warped. You wouldn't think so with drums but it happened an old VW I had because the bolts holding the drums on were torqued down too hard.It only happens when I put on the breaks.
