Does any one know what the fluid capacity on each of these differential?
H happything · Registered Joined Dec 6, 2011 · 3 Posts Discussion Starter • #1 • Feb 21, 2012 Does any one know what the fluid capacity on each of these differential?
Chris · Premium Member Joined Nov 15, 2011 · 6,657 Posts #2 • Feb 21, 2012 I believe each one will hold just over a quart.
A atjeep · Registered Joined Nov 30, 2011 · 3 Posts #3 • Feb 24, 2012 To the bottom of the filler hole. From the FSM: Dana 30 - 3.76 pints Dana 35 - 3.5 pints
H happything · Registered Joined Dec 6, 2011 · 3 Posts Discussion Starter • #5 • Feb 24, 2012 Im have aftermarket diff covers and the hole is higher than stock. Thanks for all the help
RikRotorhead · Internet Owner Joined Nov 19, 2011 · 9,510 Posts #6 • Feb 24, 2012 Fill it 'till it drips.
RikRotorhead · Internet Owner Joined Nov 19, 2011 · 9,510 Posts #8 • Feb 24, 2012 Xpress said: Fill it until it breaks. Click to expand... I can finally use this emoticon.....
Otahyoni · Premium Member Joined Nov 16, 2011 · 660 Posts #9 • Feb 25, 2012 This is the period where the thread gets derailed.... the point right after the question is answered...
RikRotorhead · Internet Owner Joined Nov 19, 2011 · 9,510 Posts #10 • Feb 25, 2012 So what should we make the thread about since the question has been answered? Why do we put air in our tires and not helium to make our cars lighter?
Chris · Premium Member Joined Nov 15, 2011 · 6,657 Posts #11 • Feb 25, 2012 I put gas in one and water in another, the third has oil and the forth brake fluid just so that I always have extra no matter where I go.
Aubster · Registered Joined Jan 8, 2012 · 86 Posts #12 • Feb 29, 2012 Hmmm... How much gas does a 33x12.5x15 hold?
Xpress · Registered Joined Nov 17, 2011 · 1,608 Posts #13 • Feb 29, 2012 About 25 gallons. Hell fill all 4 with gas and you're freaking set.
H happything · Registered Joined Dec 6, 2011 · 3 Posts Discussion Starter • #14 • Mar 1, 2012 Thanks but the question was never answered the answer is Dana 30 = 2.5 pints Dana 35 = 3.5 pints
Chris · Premium Member Joined Nov 15, 2011 · 6,657 Posts #15 • Mar 1, 2012 atjeep said: To the bottom of the filler hole. From the FSM: Dana 30 - 3.76 pints Dana 35 - 3.5 pints Click to expand... One of the two above may be right.
A atjeep · Registered Joined Nov 30, 2011 · 3 Posts #16 • Mar 2, 2012 I may have been wrong on the Dana 30, it was from a 97 TJ FSM, which has the LP Dana 30.
