These are what you are looking for. It's unlikely you will use the doughnuts, but instead the 'C' clamp and cylindrical spacers.
A warning, if the ball joint has a rubber boot held on with a spiral lock ring, remove both the rubber boot with the spiral ring before trying to push through the spindle ball joint hole. Then put them back on. Not difficult with a small pick or screwdriver...........actually easy. If you don't you might likely cut or tear the boot while trying to force it through the ball joint hole, even gooped up, it's just too big to go through.
