Head right into your next off-road adventure and battle some of the toughest terrains with the confidence using the new Hydraulic Long Travel Recovery Jack by ARB. For maximum strength and everlasting durability, it is made of premium-quality aircraft-grade 6061 T6 aluminum that ends up with the heavy-duty, high-density polyethylene construction that provides excellent grip and eliminates the risk of slippage.
The system features 9 hooking points, with a lifting range from 6" to 48" and offers a maximum lifting capacity of up to 4,400lbs. The operation process is easy and quick, which allows you to complete the trickiest of recovery missions safely and successfully.
ARB - Hydraulic Long Travel Recovery Jack
Specifications:
Click here for more information about the new ARB Product Release.
Specifications:
- Base Diameter: 6.5"
- Minimum Lifting Height: 6"
- Maximum Lifting Height: 28" - 48"
- Travel: 21" - 22"
- Lifting Range: 6" - 48"
- Maximum Capacity: 4,409lbs
- Compressed Height: 35"
- Extended Height: 56"
- Weight: 23lb
- Lift Per Stroke: 0.5"
- Designed to help to get your job done right
- Manufactured utilizing the highest quality materials
- Built to provide exceptional levels of durability
