1 - 6 of 6 Posts
I have a '95 6 cyl. With stock everything. The tires are getting scary. I found a set of 31" tires with the rims for a good price on Craigslist. The description just says "from my 2001 Wrangler" Will this lug pattern work for me? This is my 1st Wrangler (got it used last year)So any random tire tips would be appreciated. Thanks, R
Yes they will fit bolt pattern wise. You might want to trial fit one on the front to check for rubbing when you turn your wheel to full lock, left or right.
Yes they are both 5 on 4.5 lug patterns.
No problem at all, you're welcome.
I'm running 2001 Rubicon wheels on my YJ also with 33X12.50/16's and no spacers.
That's a big fat tire but I have a 2.5 inch suspension lift, 1 inch body lift, and TJ flares. I don't rub in the back at all.
The fronts rub at full compression full turn but just barely.
Jeep bolt patterns
41-86
87-06
07-
1 - 6 of 6 Posts
