What causes the fuel to drain out of the float bowl when the engine is NOT running?
  • Float Valve
    Votes: 0 0.0%
  • Check Valve
    Votes: 0 0.0%
  • Fuel Pump
    Votes: 0 0.0%
  • Other
    Votes: 1 100.0%
jeepsterdave
Discussion Starter #1 (Edited)
I have an early 1988 YJ Wrangler with a 4.2 liter engine.
It is completely original and UN-restored including the carburetor.
The problem I am having is when it sets for more than 4 or 5 hours the fuel drains out of the float bowl. then I have to grind on the starter to get fuel back in the carburetor before it will start. If it only sets for no more than 4 hours it will start right up.
Has anyone had this problem and if so what is causing/allowing the fuel to drain out of the float bowl?
